- JCE MediaBox 2.0.13 inserting code in JCE Editor link properties box
I searched FAQ's and have no result to my issue. Possibly a bug as it occurred either after a Joomla update and the latest JCE update.
Issue/bug:
When I make a link with the editor it no longer opens in a new window when I set that option in the link dialogue box.
It opens in a pop-up frame like a media manager pop-up image and not in a new window/tab.
I have never seen this before in JCE nor Joomla.
I have another site and the same version of JCE / JCE MediaBox and it does not do this.
The difference may be the one having issues (dodbits.com) is running on Joomla! 3.9.13
The working site is running on Joomla! 3.9.8 (sturmbot.org)
When I place a link in, the JCE editor is inserting this before a link... class="jcepopup"
Look at this test page... http://www.dodbits.com/dods/index.php/half-life-1-games/112-test-article-for-editors
Any idea what is going on? Why is mediabox inserting code... when I am using the link button in the editor?
At the moment I have to uninstall JCE MediaBox 2.0.13 if I want to insert links of any type, they all end up in pop-ups. Very annoying issue this one Ryan.
Need help
Edit: I have sent you a PM should you need site access to test.
Kim.
Issue/bug:
- If I change the editor to TinyMCE it does not have this fault.
- I uninstalled JCE MediaBox 2.0.13 and all links I make are working correctly.
- I reinstalled JCE MediaBox 2.0.13 and all links I made end up in a pop-up not in a new window.
Need help
Kim.
In Editor Profiles -> Plugin Parameters -> Link, in the Popups section, you had the Default value set to JCE MediaBox Popups, so this was the default selected value in the Popups tab in the Link dialog, which resulted in all links being configured as popup links.
I have set this to Not Set on your site, which fixes the issue.
Thanks for the support, I did check that section but seeing it is called "Popups" I thought it would only control image popups not text links.
It certainly caught me out, "Popups" to me is what I use in JCE MediaBox.
What I thought this was...
I was separating "Links" as the section that controls text links.
Then "Popups" as something I only use in JCE MediaBox.
Perhaps consider a warning there?
Warning: Altering from the default "Not Set" will override all link settings in the editor.
Something that would prompt the user that this setting actually overrides all links?
You would think a simple setting like that could not override the editors links dialogue box...
https://www.joomlacontenteditor.net/support/documentation/links/the-link-dialog-interface
Or... if it did, the options in the "Target" dropdown would not be enabled?
Anyway... thanks for the fix Ryan, this one really got me.
Been using JCE for a long time and figured out all issues that come up but this one.It was a bit cryptic.
Kim.
Kim.
