I just moved 23 websites from one Bitnami.com Linux stack to another one on AWS, and now updating JCE Pro is not working correctly. If I click Update in the Manage section, the extension installs (pkg_jce_pro_286.zip), but after installation, it is still listed in the Update section as needing to be updated. In addition, the JCE menu option under Components disappears. If I go to the Control Panel, I can navigate my way back to the component, but this should not be happening!
I use JCE Pro on ALL these sites, so I am very concerned that things are going to get worse. Here is the information from one instance with this problem:
Setting Value
PHP Built On Linux 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64
Database Type mysql
Database Version 8.0.18
Database Collation utf8mb4_general_ci
Database Connection Collation utf8mb4_0900_ai_ci
PHP Version 7.3.14
Web Server Apache
WebServer to PHP Interface fpm-fcgi
Joomla! Version Joomla! 3.9.15 Stable [ Amani ] 27-January-2020 15:00 GMT
Joomla! Platform Version Joomla Platform 13.1.0 Stable [ Curiosity ] 24-Apr-2013 00:00 GMT
Do you see anything that could be causing this instability?
Please advise, and thank you!
Setting Value
Database Type mysql
PHP Version 7.3.14
Web Server Apache
