- Captions class causing problems
I'm having a lot of issues with the captions. Does JCE perhaps wrap them with a formatting, I see its adding a div or two. You see it is creating a conflict with JCE Optimise because I now have three captions under each picture.
I suppose then, they must come with the Gantry template. I do not have another caption plugin in use. However I have the same type of problem with my maps. What would you suggest I do? I had JCH switched off for a while, I need to do some work. However today when I turned it back on (it was the new version which I hadnt used before) I saw these small problems.
This may be the cause then, as it looks like things are being processed 3 times, which is why you see 3 captions.
Have you played around with the JCH settings? I can take a look if you want -> https://www.joomlacontenteditor.net/contact/site-login
I did didnt I? But I just saw you are in, so I suppose you found it.
No, I've not received anything. Please use this form only to send the login -> https://www.joomlacontenteditor.net/contact/site-login
Hi Ryan? Can you just check something because now I cant get the style sheets to drop down which is a bit annoying. I just checked global configuration and changed Template Style to Custom file and added the path to custom style however that didn't change anything so I was wondering what did? I havent otherwise touched since you were in there. Cheers, Liz
Hi Ryan, I used a css file this time, called it editor.css and put it here : https://www.dolcevia.com/nl/templates/g5_hydrogen/editor.css
However it still doesn't work...
You still had an scss file assigned in Editor Profiles -> Plugin Parameters -> Style Select. I have removed this value and the Styles list is displaying in the editor again.
