what should I do after installing jce pro, step by step, as a begginer?
#107463 jce pro
Latest post by Ryan on Wednesday, 14 April 2021 10:55 BST
Wednesday, 14 April 2021 09:36 BST
ivebabek
Wednesday, 14 April 2021 10:15 BST
Are you familiar with the editor? Did you upgrade from JCE Core, or is this a clean install of JCE Pro?
Wednesday, 14 April 2021 10:23 BST
ivebabek
I had jce, and now I installed JCE Pro, but I don't know what to do step by step, on global configuration I see can see JCE editor Pro, but I also this blue sentence, Default permissions used for all content in this component. Do I have to change any permission setting?
( ... the Manage the permission settings for the user groups below. See notes at the bottom.... what should I do here?)
Wednesday, 14 April 2021 10:28 BST
ivebabek
I installed JCE Pro from my jce on joomla
Those permission settings can remain the same unless you need to give other user types access to JCE Admin functions. They don't relate to using the editor in articles etc.
If you already use JCE, then you will need to assign the new Pro buttons you require to the editor toolbar. Please see - https://www.joomlacontenteditor.net/support/faq/editor/pro-buttons-missing-after-upgrade
Please wait
Your post is being submitted…
