We found a Bug/Problem with JCE Mediafield using custom fields (com_fields) and articles (com_content). I made a new field via com_fields -> repeatable typ -> in there are 3 media fields (images). We used JCE Pro 2.9.3 and everything is working, after updating to Version 2.9.4 or 2.9.5 i can select an image via the jce media popup but after submiting (update/insert button) the pop up closes and the media field is still empty. I installed version 2.9.3 again and everything is working again.
There are no errors in the Javascript Console or in Joomla. I also tried the Version 2.9.6 RC3 but in this Version the Media Popup shows all the folders but no images - so could not select and insert the image.
Can you help me with that? Do you need more infos?
