- Hardly impossible to navigate using keyboard
Hi Ryan
I am testing Joomla 4.0 with JCE Editor Pro 2.9.11. There is an issue when using the keys ←↑→↓ to navigate through the text.
The keys ←→ are ok
With the keys ↑↓ the cursor stops at the end resp. at the beginning of each paragraph. You can navigate through the text within the current paragraph only. Once you have reached the end of a paragraph, you need to press →. This places the cursor into the following paragraph. Now ↓ works but not further than to the end of this paragraph.
Thank you and kind regards
Chris
The keys ←→ are ok
Chris
My apologies Chris. It seems that somewhere between fixing the problem and releasing the beta, the fix was removed! I have added it back in the latest beta and installed it on your site. It appears to be working now.
Please clear your browser cache before testing.
Please try JCE Pro 2.9.12 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
In my tests this was caused by the display:flex styled set on the <body> tag by the default Joomla "Cassiopeia" template. The solution was to force an override of this style.
Please clear you browser cache.
in my opinion the Cassiopeia Template is not involved when editing an article in the Back-End. Right?
If I switch to TinyMCE Editor, the cursor behaviour is normal.
JCE loads the template stylesheet into the editor so that the editor content is displayed with the template's styles. In this case, the display:flex style I referred to earlier is applied, causing the issue. The Joomla Tinymce editor does not load the template's styles.
Ok, I see. I would like to set the correct option for the «display» parameter in my user.css. But there are so many possibilities. Which one would be appropriate?
display: none;
display: inline;
display: block;
display: contents;
display: list-item;
display: inline-block;
display: inline-table;
display: table;
display: table-cell;
display: table-column;
display: table-column-group;
display: table-footer-group;
display: table-header-group;
display: table-row;
display: table-row-group;
display: flex;
display: inline-flex;
display: grid;
display: inline-grid;
display: ruby;
display: ruby-base;
display: ruby-text;
display: ruby-base-container;
display: ruby-text-container;
display: run-in;
display: inherit;
display: initial;
display: unset;
display: none;
display: inline;
display: block;
display: contents;
display: list-item;
display: table;
display: table-row;
display: flex;
display: grid;
display: ruby;
display: ruby-base;
display: ruby-text;
display: run-in;
display: inherit;
display: initial;
display: unset;
