- Problems with JCE Editor
I have a few problems with JCE Editor in Joomla 4:
- The File browser is only visible on the screen as a very small window. See the image: JCE Editor-File browser.JPG
- Within the Current Editor Layout, all icons are displayed in one column, rather than in rows. See the image: JCE Editor-Current Editor Layout.JPG
- In the Editor Parameters screen I cannot use the tabs Typography, Filesystem and Advanced. See the image: JCE Editor-Editor Parameters.JPG
How can I solve this? I already reinstalled the extension, but that did not help.
#108845
I've made some changes now. I copied the Admin Tools settings from a Joomla 3.10 installation and now everything seems to work!
As @deroderuiter found after the tip @Ryan gave, the issue relates to .htaccess file generator settings in Akeeba Admin Tools.
Add:
To Admintools .htaccess generator in the "Allow direct access, except .php files, to these directories" section, and it will allow the CSS files that are being blocked to be loaded.
Add:
administrator/components/com_jce
JCE Pro 2.9.18 Beta 9 - https://www.joomlacontenteditor.net/downloads/editor/pro/development - moves the asset media for the JCE Admin out of the administrator/components/com_jce folder and into the media/com_jce folder, which will "fix" this issue.
