I am reporting the following issue encountered on three different multilingual Joomla 4 websites.
How to reproduce ?
- Install a Joomla 4 website using Multilingual Sample Data (PHP 7.4).
- Install another language: french in my case.
- Set System - Language Filter > Remove URL Language Code.
- Install JCE 2.9.16 and set it as default editor.
- Important: set the non-english language as default language.
- Set the default menu item as a single article.
- Set Shared Sessions to Yes in order to use frontend editing.
- Go to the site global home page (without the language code in the URL) and edit the article (should be the non english content).
- Clicking save should trigger an error like this one and won't save any data:
2021-10-23T12:41:52+00:00 INFO ::1 controller Holding edit ID com_content.edit.article.14 Array ( [0] => 14 )
2021-10-23T12:41:52+00:00 INFO ::1 controller Checking edit ID com_content.edit.article.14: 1 Array ( [0] => 14 )
2021-10-23T12:41:56+00:00 CRITICAL ::1 error Uncaught Throwable of type Error thrown with message "Call to a member function format() on bool". Stack trace: #0 /Users/christophelance/Sites/joomla4/libraries/src/Form/Form.php(1149): Joomla\CMS\Form\Field\CalendarField->filter('23-10-2021 13:2...', NULL, Object(Joomla\Registry\Registry))
#1 /Users/christophelance/Sites/joomla4/libraries/src/MVC/Model/FormModel.php(218): Joomla\CMS\Form\Form->filter(Array)…
Note: switching to tiny mce doesn't trigger any error.
Thanks for your help,
Christophe
