#109334 problem applying styles : they are ticked but not applied
Latest post by Ryan on Thursday, 11 November 2021 09:52 GMT
AlainR
Hi.
We have several Styles in the drop-down menu from a style sheet dedicated to the editor. When we select several paragraphs and choose the style, it is checked in the list but it does not apply.
When we select several paragraphs and choose the style, it is checked in the list but it does not apply. I think this problem has been happening for some versions, unfortunately I don’t know which one, since the users did not provide me with the information right away.
This is working for me in tests on a local development site and on the demo site.
Are you able to reproduce this issue on the demo site? - https://demo.joomlacontenteditor.net
AlainR
Thank you for the answer.
Yes, I can reproduce on the demo site :
  1. I select a whole paragraph, i can add Styles
  2. and we see them in code
  3. when I select several paragraphs, I can add Styles
  4. but we cannot see them in code
Which browser are you using?
How are you selecting these paragraphs?
AlainR
Thank you for your answer.
It was the way to select which is problematic: click-swipe works, but a triple click to select results in the selected styles not being applied.
Thank you so much for the help and the solution.
Best regards.
Thanks for clarifying, I'll look into this.
AlainR
However, it still works for only 1 paragraph, even if it is selected by triple clicks.
Ok, I can confirm this issue if you make a multiple paragraph selection, and then attempt to apply more than one style from the Styles list. In my tests, only the first is applied.
If you re-select in between applying each style, it works, but this is not ideal.
Unfortunately this looks like quite a complicated issue, so it might take some time to solve!
