#109978 JCE MEdiaBox 2.1.2 problem on Android
Latest post by Dumbo on Thursday, 08 September 2022 18:56 BST
Dimps1
Hi there. I have just installed JCE MediaBox 2.1.2 on Joomla 3.10.4, but the image popups don't work on an Android phone. They hang on the "waiting" circle going round and round. Suggestions?
This is working fine in my tests with an Android device using the examples on the MediaBox site - https://www.joomlacontenteditor.net/products/jce-mediabox
Please post a link to an example popup.
Dimps1
Thank you for your prompt response. I have copied and pasted this code from your Single Image Popup example into one of my pages:
<p><a class="jcepopup" title="Nature::Flower" href="https://cdn.joomlacontenteditor.net/images/mediabox/flower.jpg" target="_blank" rel="noopener noreferrer" type="image/jpeg" data-mediabox="1" data-mediabox-group="image"><img src="https://cdn.joomlacontenteditor.net/images/mediabox/thumbnails/thumb_flower.jpg" alt="flower" /></a></p>
I'd be grateful if you could look at my page and let me know what I'm doing wrong. It works perfectly on other devices but not on an Android phone in Chrome: https://royalalfredmarina.com/community-classifieds-archives I am attaching a screenshot from the phone. Thank you.
Does your phone open popups on the MediaBox site? - https://www.joomlacontenteditor.net/products/jce-mediabox
hardys
@Dimps1 The popup on your site opens without problem on my Anroid 12 phone with Chrome
Dimps1
Hi Ryan & Hardys,
Thank you both for your replies. I have now tested the popups on Android phones using Chrome, Edge, Firefox and Opera. They work in every single browser except in Chrome on one of the phones tested - mine, unfortunately. So it seems that the issue is with one particular phone. Thank you both so much for your help with this issue and I am sorry to have wasted your time.
Cormoran
I have the same problem on Android with Chrome. Some times it works but most of the time it hangs with the turning circle !
Any ideas ?
@Cormoran# - Ar you able to play the examples on the MediaBox page? - https://www.joomlacontenteditor.net/products/jce-mediabox
Cormoran
Yes, and everything is OK !
@Cormoran# - Please post a link to an example on your site that is not working.
Dumbo
You have to give each image target="_blank". This solved the issue on my website.
