- Add 3 fonts to JCE
Please see - https://www.joomlacontenteditor.net/support/tutorials/editor/adding-and-removing-fonts#webfont
johnmendivel
selected the reply #110503 as the answer for this post — 3 months ago
#110722
hello explain me step by step please
https://fonts.google.com/specimen/Barlow
for the barlow font for example, it doesn't work for me, how can I install this font?
#110745
is the family font name ok?
the @import that should be put, what is it?
@import url(http://fonts.googleapis.com/css?family=barlow);
or
@import url('https://fonts.googleapis.com/css2?family=Barlow:ital,This email address is being protected from spambots. You need JavaScript enabled to view it.;0.200;0.300;0.400;0.500;0.600;0.700;0.800;0.900;1.100;1.200;1.300;1.400 ;1,500;1,600;1,700;1,800;1,900&display=swap');
or
Yes.
or
You need to selec the styles you require here - https://fonts.google.com/specimen/Barlow#standard-styles - and then copy the @import rule (the bit between the <style> tags) to paste into your template stylesheet, eg:
@import url('https://fonts.googleapis.com/css2?family=Barlow:ital,[email protected],100;1,100&display=swap');
