- Modal Popup in frontend does not work in every template
Since the last update I noticed that the modal popup on the article images doesn't work anymore. You get the error message: "The server IP address of index.php was not found." I could already find out that this is related to the template and which javascript this template uses for the modal popup. So it works with "protostar" but not with "Beez3". The URL from the broken modal popup link inserts the URL base (usually a slash) twice.
Please try JCE Pro 2.9.23 RC - https://www.joomlacontenteditor.net/downloads/editor/pro/development
