- Icône Tooltips CG is not visible in JCE Pro (but ok in Tiny)
Hello
I use tooltips from regular lab in my Joomla 3 site https://www.marketingformation.ch . I need to upgrade to Joomla 4 and there is no compatible version at Regular lab.
I bought Tooltip CG from JoomlaCK.
I can't find the button that should be added to JCE Pro (last beta version).
In Tiny MCE it works.
Have you added the Joomla button (the one with the Joomla logo) to the editor toolbar?
When this button is added the toolbar, the editor-xtd buttons usually displayed below the editor are added to a menu accessed from this button.
Yes the Joomla button is added and now if I click on this button I see more buttons, but not below
Yes, the is the expected behaviour. With this button in place, the buttons below the editor are not shown.
and how to remove the Joomla button so that they are at the bottom?
The same way you added it, in Editor Profiles -> Features & Layout. Drag the button out of the Current Editor L ayout back into the Available Buttons & Toolbars.
marked this post as Resolved — 1 year ago
