#111646 Problem after upgrade to J4
Posted in ‘Suggestions & Feature Requests’
Latest post by Ryan on Tuesday, 09 August 2022 09:43 BST
thonline
Hi!
I have, since the upgrade to J4, an error message reading "Error 500 behavior.caption Not found".
I've read on this page in the forum.joomla.org that you have found a quick patch to get around that problem.
Is that true? Because I don't find the solution to make the site (frontend) work, the backend is working though.
So maybe you can help me here and tell if there is such a patch from you and where I would find it.
Thanks a lot for your help
Frank
---------------from the forum.joomla.org--->https://forum.joomla.org/viewtopic.php?f=815&t=989032
//Re: Error 500 behavior.caption Not found
Post by DV-admin » Wed Feb 16, 2022 1:42 pm
Joomla JCE Editor developer has been able to fix this with a quick patch//
Which version of JCE Pro do you have installed? JCE Pro does not reference JHtml::_('behavior.caption'); in the admin.
