Hi, I have a fairly complex problem and I will try to describe it as best I can.
I am creating a web app that, by means of some forms, stores texts, images and tables in a mysql database. Then I export the data in a CSV file and send it to a company that has to provide automatic pagination. This company uses Adobe Indesign Server.
I created my app using the "Fabrik" software installed in Joomla. As an editor I used JCE Pro and everything works fine. The problem is that all the data is stored in html and the Indesign server does not interpret the html.
I would need to "convert" the html tags to another format. Here is an example:
<h1> Example title H1 </h1> should become <Tit100H1> Example title H1 </Tit100H1>
The Tit100H1 tag is a tag that refers to a style appropriately configured in Adobe Indesign.
Then there are other tags that I should convert but it is still the same operation.
Can you advise me how to do this conversion? I have no idea how to do it.
Thanks for those who want to help me.
