#111979 Joomla 4 content not loaded and saved
Latest post by Ryan on Wednesday, 26 October 2022 16:44 BST
yann112
I migrating a Joomla 3 to 4.
Last version isntalled -> Joomla 4.23 / JCE 2.9.30
Problem 1 :
When I edit an article, the editor is empty but if I click on the button "code" I see all article content.
If I click agin on the button "code" to switch to editor mode, the content is display.
Problem 2 :
I the editor mode is enable, the new content is no saved. (normal confirmation message but no change stored in db)
I have the problem only with JCE, by example TinyMce work fine.
How Can I fix that ? Maybe a problem with the configuration of JCE with Joomla 4 ?
Thanks in advance for your help
Yann
yann112
I'm in localhost to prepare the migration... so sorry I can not provide you a login.
Do you want screenshots ?
Yes, that might help.
yann112
I have attached four screenshot.
For informations :
The content is not loaded on step 2 in the editor mode.
If I save on step 3 (code source display) the content is saved correcly.
If I save on step 4 (editor mode) the content is not save.
What is the icon in the top right corner of the editor content area?
Is you browser reporting any javascript errors in the browser console when you load the editor?
yann112
The icon is "scriben", a spell checker (plugin bowser).
I have desactivate to be sure, same behavior.
For the console, I checked and I see an error (see attachment)
Have you added and Custom Styles in Editor Profiles -> Plugin Parameters -> Style Select?
yann112
from memory it seems to me that not but when I wanted to verify, I have an error 500 (see attachment)
Link : /administrator/index.php?option=com_jce&view=profile&layout=edit&id=1
Apache Log : Fatal error: Maximum execution time of 30+2 seconds exceeded (terminated) in /website_path/libraries/vendor/joomla/database/src/DatabaseAwareTrait.php on line 43
PHP 8.0.8
Joomla 4.2.3
Please select the Default profile and click the Export button, and save the profile to your computer.
Select all the profiles and click the Delete button.
Go to System -> Manage Extensions and uninstall the JCE Pro Package.
Re-install JCE Pro 2.9.30 - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
Does the editor load now?
yann112
For information, before I used JCE (normal) latest version 2.9.30.
I have delete all profiles and extension as requested. (see attachements -> error on deleting -> maybe because all items selected in one time)
After I have re-installer JCE (Pro) latest version 2.9.30.
-> Now the editor works fine thank you (no JS error). The content is loaded correctly (editor mode and/or source code) and save the changes in all cases.
-> But I have always the internal error 500 when I click on default profile. (the "default" profile is this one installed by JCE, I don't have imported the old profile -> I don't need to import but I would like solve the error 500 if I want edit the default profile in the futur)
What is the PHP memory limit value on your server?
yann112
Actually I'm on localhost to prepare the migration -> memory_limit = 512M
I'm not able to reproduce this error in my tests, and it's impossible to troubleshoot if I don't have access to the site with the error.
yann112
For the moment I don't have the time mount a server special for you and clean confidential content, I must continue my migration.
I have debuged the profile view in adminitration (administrator/components/com_jce/views/profile/view.html.php), the line that generate the error 500 is the 58 : parent::display($tpl);
var_dump($tpl) => null
For information, the website is a J3 migrated to J4 -> problem.
And I also tried to a new installation J4 -> no problem.
I have noted that stay J3 code (by exemple JFactory:: instead of Factory:: or the structure of component), can you confirm that JCE is completly compatible with J4 ?
Thanks in advance
I will wait until you have completed your migration before commenting further, if you are still experiencing the issue on your site site.
Yes.
yann112
Migration done, problem still only on dev environement (local server MAMP Pro with PHP 8.0.8) if you want try to reproduce it.
I use MAMP Pro with PHP 8.0.14 and I am unable to reproduce this issue.
