- Problems with PHP 8.1
I have a Joomla 3.10.11 site using JCE Editor Pro 2.6.31 and I have just converted it to use PHP 8.1. However I can't then get into the Articles because I get an HTTP 500 error. If I disable JCE Editor Pro and use another editor then I can get in without a problem. Are you aware of this issue - can you fix it?
Gary
Gary
Please download and install the latest version of JCE Pro - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
marked this post as Resolved — 3 weeks ago
I have a Joomla! 3.10.11 site using JCE Editor Pro 2.9.33, running with PHP 7.4.33 without any problems.
Now I have just tested it to use PHP 8.0 or 8.1. Unfortunately I can't edit any article because I get an HTTP 500 error.
If I use the integrated Tiny MCE instead of JCE, the articles can be edited without any problems.
What's wrong? Any idea?
Thanks Hartmut
Thanks Hartmut
If you switch to "No Editor" or "CodeMirror", do you get the 500 error?
I'm not able to reproduce this in my tests. Please send me a login - https://www.joomlacontenteditor.net/contact/site-login
