- Econa plugin issue after upgrade to 2.9.37
Hi! After the update to 2.9.37 we have an issue with the Econa custom field plugin from Firecoders. I have also contacted Lefteris about this but when I turn of the JCE Editor plugin in the backend the Econa plugin works fine.
The issue is that we can not use the buttons in the econa custom field anymore. Joomla flips to the article list view and the article is locked. When I turn of the JCE plugin the econa plugin works again. I suspect it's a javascript issue? Also, when the JCE plugin is disabled (JCE Editor Pro - Administrator-Component) the close button of the article stops working. Not sure it that is related.
This is only an issue on Joomla 3.
Joomla! 3.10.11
JCE Editor Pro - 2.9.37-rc2
PHP 8.0.28
Joomla! 3.10.11
PHP 8.0.28
I have fixed this on your site with an install of JCE Pro 2.9.38 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
jjonker
changed the title from Econ plugin issue after upgrade to 2.9.37 to Econa plugin issue after upgrade to 2.9.37 — 1 week ago
I don't have the plugin in question to test with, can you send me a login? - https://www.joomlacontenteditor.net/contact/site-login
This is caused by a javascript error in the Econa /media/econa/js/main.min.js file, which then prevents further processing of Econa HTML, so the buttons you press execute a page submit rather than their intended function.
It looks like there is just a simple conflict here, where Econa is trying to convert the Joomla Media Field after JCE has converted it. In this instance its probably easiest just to disable Media field conversion by JCE, as I suggested above.
Yes we could change that setting to make it work but that would also mean users will see the Joomla media editor when the use the 'media' button in the Econa plugin. If we want the JCE media browser to be used here, the conflict would need to be resolved? Maybe Lefteris (from Econa) could have a look at that.
And this issue is only J3 related? In that case we should probably upgrade asap anyway ;-)
Yes you can. No problem
Leferis (Econa developer) asked: I want to note that everything works fine with JCE 2.9.36. Probably something changed in JCE 2.9.37. Maybe the guys at JCE can share some more information regarding the last JCE update so we can fin the issue quickly.
