  Thursday, 25 May 2023
  360 Visits
When adding a collapse div (bootstrap 5) then it is not possible to edit collapsed content.
<div id="collapse-3" class="card-collapse collapse">
Test
</div>
Removing class collapse shows content.
Any workaround in editor? Like "show hidden elements" function or so that I am missing?
#113841
You need to clear your browser cache after making any changes to your template stylesheet.
Also, set Compress CSS to No in the Editor Global Configuration, to check the change, then you can re-enable it.
#113838
Add the following to your template stylesheet:
.mceContentBody .collapse {
display: inherit;
#113839
Didn't work. The style does not affect the collapse even though i added a custom stylesheet as last stylesheet both in admin template and in frontend template and also in JCE custom style template global configuration.
.mceContentBody .collapse, .mceContentBody .collapse:not(.show) {
display: inherit !important;
does nothing and when inspecting element with class collapse in backend then
display: none;
from
administrator/index.php?option=com_jce&task=editor.pack&type=css&slot=content& ...(hash code or something that i removed)... =1&context=22&profile_id=5
is loaded and hides the div.
#113841
IUSAB selected the reply #113841 as the answer for this post — 4 months ago
#113843
So issue was the compress CSS setting. Changed it to no and it solved the issue!
Thanks and have a good weekend!
