  Wednesday, 23 August 2023
  833 Visits
Hi
I have a website updated to joomla 4.3.4. the site have a template made with helix ultimate 2.0.14.
In the settings by helix ultimate i have a possibility to "compress javascript file". with joomla 4.3.3
and the setting with "compress javascript file" work's all fine.
when i update to joomla 4.3.4, the backend will work, but the website is turning on and on - will load, but not
is showing.
when i deactivate jce mediabox 2.1.5, the website run. what's the problem here?
here is the site, that will no run: https://www.schulezeiningen.ch/cms_3/
joomla 4.3.4/jce mediabox 2.1.5 active
#114478
The compress javascript setting is causing an issue with the JCE MediaBox script. You either need to disable the "compress javascript file" option (it doesn't provide much of a boost in modern browsers, which are optimized for loading multiple scripts in parallel) or add jcemediabox.min.js in the Exclude Javascript Files field in the Helix Ultimare settings.
#114479
Hi Ryan
OK - thank you. I will disable this in the template.
Greetings from Switzerland
