  Monday, 04 September 2023
  355 Visits
Hi, I have a problem with inserting links.
I use JCE editor on a website, latest version, Joomla 4 latest version.
I write a series of words which I then have to link to an external link.
Then I select the sentence, click on the button to insert the link, insert the link with opening in new page, and then insert.
It happens that the phrase is repeated twice.
This happens on a Windows PC, I've tried to simulate it from my workstation with different browsers, but it doesn't happen to me, but I've seen what happens on the editing PC.
Is it a cross browsing problem?
What suggestions can I provide?
4 weeks ago
#114571
In the meantime, while waiting for a response, they are informing me that the same problem seems to appear on three different PCs.
4 weeks ago
#114574
Do you have the latest version of JCE Pro installed, currently 2.9.41? - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
4 weeks ago
#114583
Yes, as I wrote, latest version of JCE and latest version of Joomla. I've seen this problem before, but I've never given it weight and I don't understand what it could be related to. Whether it's a memory issue, a cross browsing issue or whatever
3 weeks ago
#114587
Which browser(s) are your users using?
3 weeks ago
#114588
1 PC:
Windows 10 Pro
Chrome Versione 116.0.5845.141 (Build ufficiale) (a 64 bit)
2 PC:
Windows 10 Pro
Firefox
3 weeks ago
#114614
Do these words contain any formatting before you create the link?
When you open the link dialog, what is the value in the Text field?
3 weeks ago
#114615
This is what happens:
https://app.screencast.com/VmFlUBtvmSJ2s
As you can see, the text value is clean, and doubles
3 weeks ago
#114616
In the Editor Global Configuration, what is the Container Element & Enter Key option set to?
3 weeks ago
#114617
It's set to "paragraph : paragraph".
3 weeks ago
#114618
Can you confirm that this only occurs when the selected text to create the link on includes a space at the end?
3 weeks ago
#114619
Great, I just did a test, trying to put a space at the end of a string of words, and I tried, in fact it doubled the words.
So the problem is here?
3 weeks ago
#114620
Yes, thank you. I am working on it now, but until a fix is released, perhaps you can instruct your clients to attempt to make the selection without the space?
3 weeks ago
#114621
stevetheweb selected the reply #114621 as the answer for this post — 3 weeks ago
Ryan revoked the reply #114621 as the answer for this post — 3 weeks ago
3 weeks ago
#114622
Please try JCE Pro 2.9.42 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
Clear the browser cache after install.
3 weeks ago
#114623
HI Ryan,
I tried the beta version in a test area where the latest version of JCE demonstrated, with space, the same problem.
I installed the beta, and repeated the link insertion test, I confirm that now it no longer happens, even if I deliberately insert a space after the last word, select all the text including the space, insert the link, it is removed space and words are not repeated.
Thank you
Ryan marked this post as Resolved — 3 weeks ago
