  Sunday, 15 November 2015
  3K Visits
I spent some time trying to get an iframe into an article, no luck. I read what I found in this forum, and some googling. HTML cleaning switched off everywhere for anyone, iframe plugin installed etc. One success: iframes are not already stripped when toggling editor. But after saving an article, it's gone.
Joomla 3.4.5, JCE 2.5.11
EDIT:
I tested some more:
Standard article: When toggling the editor, all attributes are removed. Saving the article, the iframe will not be stripped - so as long as I don't toggle, it's ok.
Text in JEvents: attributes removed on toggle, iframe stripped on save.
#83518
In Editor Profiles -> Editor Parameters -> Advanced, have you added anything to the Extended Elements list? If you have added "iframe", remove it.
JEvents may have additional options for text filtering, that is removing the iframe. Check the JEvents configuration.
#83518
#83519
Thanks, Ryan.
I tried both, no difference. Currently the field is empty.
Why would adding something to Extended Elements filter something out? I thought it was supposed to do the opposite?
> JEvents filtering
Indeed, there is a setting "Allow unfiltered descriptions" (Config > Event editing)
I switched this on, and now everything seems to work. I don't see how this could be related to standard articles. And now, switching the filtering back on for JEvents, standard articles are still fine.
Strange, but for the time being the issue seems solved. thanks again.
#83521
Adding just iframe to this field (which some users do), allows the iframe tag only, without any attribtues. The correct syntax is iframe[src|frameborder|width|height] etc.
