- How does markdown work?
Hello there,
First of all, congratulations with the new version of your editor. It looks really interesting, even though there seems to be some issues. I guess most of them are cleared when you empty your Joomla caches, as well as the browser's.
Anyway, I am testing the new markdown features of JCE 2.6.0, but I can't seem to get it working. Besides checking the tick mark in the profile's settings, is there something else to do? To you have to work in the editor window or in the code one?
#87471
Well, it seems to work after all. You need to log out of the back end and log in again to validate the change in the profile. Other changes (like code or preview tab) are applied without logout/login.
Markdown is applied in the editor window, using the Markdown syntax - https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet
Please Note - Links and Youtube videos are not supported yet.
So to create a H2 type heading, you type in ##Heading and press enter and the text is formatted as a heading.
For bold text, you type **some text** ad the text is made bold.
#87471
#87481
Great video. The only thing I can't do is the latest: the code to insert an upload zone. I just get an empty image with this code:
<p><img alt="" width="320" height="240" data-mce-upload-marker="1" /></p>
Do I have to activate something somewhere?
