  Thursday, 27 April 2017
  11K Visits
When I submit a news article through the front end of the website I get a Warning Empty solution not allowed. I can submit the news article through the backend.
Joomla 4.7
Latest JCE Pro
PHP 7
I turned on the development error settings and I didn't see any errors.
Thanks.
Jeff
#91509
Same problem for me
Joomla 3.7.0
php 7
jce pro 2.6.12
Robert
#91512
I do get a few js errors:
Error parsing header X-XSS-Protection: 1; mode=block, 1; mode=block: expected semicolon at character position 14. The default protections will be applied.
#91513
This is a captcha conflict
Disable the default capcha and it's working !
#91515
Thanks i-media. I tried that, now I get:
Error:
0 - Call to a member function checkAnswer() on null
I have a feeling this is a template issue.
Jeff
#91518
Do yo get the same error with the Tinymce editor?
#91521
Yes. Same error with Tinymce editor !!
#91531
Same here, 3.7 and 2.6.8. Looks like 3.7 must have changed something.
#91540
I'm having the same issue. Is is Joomla 3.7 or the latest JCE update? I'm unable to edit pages from the front end - this is a disaster! This needs fixing asap.
#91541
I updated to 3.7 and PHP7 and I can not edit on front end either. Also I am getting the following error when trying to edit in back end.
Fatal error: Switch statements may only contain one default clause in /home/www/http://exploreatlanticcanada.ca/components/com_jce/editor/libraries/classes/document.php on line 279
Gary
#91542
The fix for me was to disable captcha-recaptcha in the global config and enable it in the contact options. After disabling it in the global config the error was gone.
Dan.
#91546
Disabling the global Recaptcha fixed one site and I also had to turn off progressive caching on another site.
I switched to Tinymce editor and received the same issues so this is a Joomla issue.
Jeff
#91547
Gary
@Simwombat - this is a completely different issue to the one originally posted, and yours can be easily solved by upgrading to the latest version of the editor - https://www.joomlacontenteditor.net/downloads/editor/item/jce-pro-2-6-12
#91553
As from 3.7 it appears that captcha can be enabled at article level and although by default 'Allow Captcha on submit' is set to 'None Selected' it is in fact enabled.
The fix is to go to Content | Articles | Options and click on the 'Editing Layout' tab and click 'Save'
Trevor
#91559
Thanks trevorsm !
This method also works for me !
#91918
Thank you for posting this question. The solution of setting "Allow Captcha on submit" to "None Selected" worked for me too.
In our website's case, when I edited the article by logging in to the Joomla back end and using JCE from there, I did not see any error message and could save articles just fine.
However if I edited the article by logging in to the website FRONT END and editing the article by hitting the edit icon, THEN I got the error message (but no more, after applying the fix).
I edit from the "back end" but my user who reported the problem edits from the front end, so I didn't know about the problem right away.
Carol Mattsson
http://surfpix.net/web
