A mediabox popup that opens article content from your local site, uses a special file in your template (component.php) so that the page is shown without modules.
If you are using a custom template, you should make sure this file exists, and that it is loading the template stylesheets correctly.
You can see an example in templates/protostar/component.php
Please Click btn: 'OTWÓRZ KALKULATOR'
On my own template:
http://ancacars.cftb.pl/oferta/kalkulator
On Protostar template:
http://ancacars.cftb.pl/oferta/kalkulator2
On my own template:
I've another problem, when I add
class="jcepopup" type="text/html" data-mediabox="1"
to my link, other things stops working like this"
forms from chronoforms - all JS stops working.
When I delete class="jcepopup" type="text/html" data-mediabox="1" form link other JS from chrnoforms works but css doesn't work.
If it possible to use CSS and JS Chronoforms in jce popup window?
Regards
Regards
When using type="text/html", the content is loading into the popup using ajax, so any scripts that run on the content will not be executed.
You will need to use the iframe method (do not add type="text/html" and add the template css to the template component.php file, as suggested in my previous post.
Looking at the source code of your component.php file, it loads scripts, but not stylesheets.
Add the following in the <head> section of the component.php file:
<link rel="stylesheet" href="/templates/cftb/css/bootstrap.min.css" type="text/css" />
<link rel="stylesheet" href="/templates/cftb/css/style.css" type="text/css" />
<link rel="stylesheet" href="/templates/cftb/css/responsive.css" type="text/css" />
<link href="https://fonts.googleapis.com/css?family=Open+Sans:300,400,600,700&subset=latin-ext" rel="stylesheet" />
Your site seems to use multiple templates. I am not sure which one is used where.
I have created a component.php file in templates/cftb/
You may need to edit this to get the output you require.
Please see this - https://docs.joomla.org/Understanding_Joomla%21_templates
and - https://docs.joomla.org/Customizing_the_print_pop-up
