- Can't echo with PHP on custom module
Hello!
I'm trying to print a simple date with php.
The code would be:
and the custom module has the "prepare content" enabled. I save the code on the editor view instead of code because if I do it on code it will change the php tags to a span tag and comment out my code.
JCE has php enabled on my profile.
site is http://www.zeta.com.pa and date should appear just after the email This email address is being protected from spambots. You need JavaScript enabled to view it.
The code would be:
<?php echo date(); ?>
PHP code cannot be executed inside content or module items. You need a special extension, like Regularlabs Sourcerer - https://www.regularlabs.com/extensions/sourcerer - to do this.
