- JCE Plugins / Addons
- Can not resizing images by percentage in articles
I have been trying to edit an image size by using percentage but am unable to get it to change.
I used to add ex: 30% and the NaN would show up automatically on the other size but this is not happening.
I have tried manually entering NaN but that does not work either.
All this has happened since last update it was working fine before.
These are blog articles found under travel blog but of course the one I can not get to size is not there.
Hoping someone has a suggestion.
Thank you
Gary
Thank you
Gary
There is a small bug here. Although the calculation is ignored because of the % value, notification of the change is not broadcast, so the image is still treated as having unedited dimensions, therefore the image is inserted without dimensions.
Please try JCE Pro 2.6.31 Beta 1 - https://www.joomlacontenteditor.net/downloads/editor/category/development
Nan stands for "Not a number" and it indicated an error in the calculation, as a percentage value is not expected.
Image dimensions should be in pixel values, but if you do add a percentage for one of the dimensions, then the other value will not be calculated accordingly. You will need to add this value in yourself.
well I am shocked Ryan
I have been using JCE pro and setting image size by percentages for over 3 years now and they are still working. I am not sure where you get that I have to set the other dimension as it has always just added the NaN by itself. it worked very well. I am just very surprised that all that has changed.
I am sure there are others out there doing the same.
