- JCE Plugins / Addons
- Using MathType in JCE
I would be interested to know whether JCE is compatible with MathType, a mathematical editor which can be used with Joomla/TinyMCE. There are instructions for using MathType with TinyMCE (https://docs.wiris.com/en/mathtype/apps/joomla) and as far as I know, JCE is based on TinyMCE. I was wondering, therefore, whether MathType can be used with JCE. If so, what would the procedure be?
Thank you!
Thank you!
It could, but JCE requires external plugins to be installed, like Joomla plugins.
This would require path modifications in a few of the Mathtype files, and a plugin xml file.
I will have a go at this next week if I get a chance.
