- Problem with JCE and SP Page Builder translations
Hello, I'm using JCE on a website with the component SP Page Builder and plugin Translate for SP Page Builder (Faboba). The editor is functioning correct when we fill in the standard language. But we also have 2 other languages to fill and here's the problem.
On the languages tab, there are 2 instances of JCE loaded. Now when we fill both fields, the second translation (ES) instantly overwrites the first. So everything we write in the first translation (NL) get's overwritten by the second. And the second field is empty after saving.
When we open the textblock to edit again, JCE editor is completely missing.
Could this problem be related to the use of 2 JCE editors in one screen?
It's frustrating because we can't fill the website translations now, I hope you can help me out.
Best regards, Niels
Best regards, Niels
#97216
Make a simple test.
Install older version of JCE 2.6.22 and check again.
I also noticed problem with 2.6.33 and 2.7 beta, SPPB developer was also informed.
Please try JCE Pro 2.6.34 Beta 6 and/or JCE Pro 2.7.0 Beta 15 - https://www.joomlacontenteditor.net/downloads/editor/pro/development
