  Tuesday, 23 April 2019
  12.5K Visits
- Install JCE (includes the media-manager), either pro or core, does not matter
- Create a content-plugin to add fields to the standard joomla articles (we use repeatable subforms, so we have to use a custom content-plugin)
- Insert a media-field as field inside the subform
- It shows the standard (not so powerful) Joomla-Media manager, where as in other areas (modules...) the media-fields media-manager is replaced with the JCE manager
I've reported this as Joomla-Bug here:
https://github.com/joomla/joomla-cms/issues/24653
But they say it's a JCE issue.
Can you please help?
Thanks in advance
Best regards
#99595
maybe in the form xml i need to include a field-path or something
The path is plugins/fields/mediajce
#99577
It is not possible to convert a repeatable media field into a repeatable mediajce field.
To create a repeatable mediajce field, set the type to "mediajce" in the subform formsource file, eg:
<field name="image_repeat" type="mediajce" mediatype="files" label="Media" description="" />
#99584
Hi, thanks for the response, it works!
If i wanted to use the mediajce field natively in modules too (for uploading non-image files), is it possible to do so? (If i use it like this in a module it shows a text-field, maybe in the form xml i need to include a field-path or something?)
Best regards
#99595
#99674
Thanks, appreciated!
