#116858 Problem enlarging photo
Latest post by Willem Steen on Sunday, 08 September 2024 07:57 BST
Willem Steen
I have not upgraded to Joomla 5. But now I notice that when I enlarge it, it does NOT return to its normal size.
I posted the photos via JCE/photo entry. Then use the subtitle option. By default, the size of the photo is 1500 x 988. But in the article the size is 500 x 335. So that it can be enlarged by the reader. see the appendix 1 normal, 2 enlarged, 3 not back to small.
Please post a link to an example on your site.
Willem Steen
https://www.steenfotografie.nl/fototrips/fototrip-2023-rhb-75-jaar?showall=1
Thank you for the quick response and sorry that I did not immediately send the link. it is from the page with the sample photo. but the problem is with every single photo.
hope it can be solved.
have a nice weekend
kind regards
Willem Steen
This is caused by a bug with the Scrolling option in the MediaBox parameters when it is set to Scroll, which will be fixed in the next update, along with some other inconsistencies with this option.
Until then set the Scrolling option to Fixed.
Willem Steen
Thank!. Oké now
