H Ryan,
In a future version, can we set a different column setting other than 1/1 ?
Other option : the possibility to enable/disable these columns options for only keeping the ones we want for our end users :
A content editor for Joomla!®
Latest post by Ryan on Tuesday, 05 November 2024 10:20 GMT
H Ryan,
Do you mean a default Layout, or a default number of columns?
I'm not sure to understand your question.
I mean : for now the default choice is 1/1 but in some case we prefer to have 1/2 for example as default column layout.
Ok, so I will add an option in the Columns parameters to set a default Layout.
Your post is being submitted…
