#117005 JCE pro not working
Latest post by Ryan on Tuesday, 17 December 2024 11:34 GMT
wdp
I see the extention and have entered the key. Why does the option for jce pro not show up for the global default editor?
If you have previously install JCE Core, you need to download and install JCE Pro - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
then add the Pro buttons you require to the editor toolbar - https://www.joomlacontenteditor.net/support/faq/editor/pro-buttons-missing-after-upgrade
The Subscription / Download Key enables updates for future versions of JCE Pro, it does not "activate" JCE Pro.
See - https://www.joomlacontenteditor.net/support/faq/subscription/using-the-subscription-key
