09:00 - 17:00 UTC (BST)
#117008 font awesome problem
Latest post by dpollez on Thursday, 19 December 2024 15:42 GMT
dpollez
I can't get font awesome to work properly.
In the editor listbox the icons are not visible, only the text.
Some icons are displayed correctly in the text, others don't appear at all.
I use the cassiopeia template (child) and as far as I know font awesome is not (extra) loaded by extensions, not even by the JCE pluging.
Joomla apparently loads joomla-fontawesome.min.css twice directly after each other 1st time as rel="lazy-stylesheet" and a second time as rel="stylesheet"
I have searched extensively in the forum but can't find a solution.
Any idea how to solve this?
Didier.
If you are using Joomla 5, then you need to configure the Font Awesome plugin to use FontAwesome 6.
Go to Editor Profiles -> Plugin Parameters -> Font Awesome, and set the Font Awesome Version option to 6.
dpollez
That simple, works, thank Ryan!
Didier.
