#117275 Responsify Click on Play Issue
Latest post by Rollmodl on Tuesday, 29 July 2025 16:17 BST
Rollmodl
Hello. Full width does not work when Responsify is set to Yes and 'Click on Play' is set to No. It also leaves a large white space. Also when Click on play is set to yes, no video cover image is shown (Vimeo). https://seenearme.com/
I'm not seeing this in my tests. There may be a conflict with other css on your site. Please send me a login - https://www.joomlacontenteditor.net/contact/site-login
You can set a poster image to use for the Click to Play background. See  "IFrame Poster Image" at the bottom of this page - https://www.joomlacontenteditor.net/support/documentation/plugins/responsify
Rollmodl
Sent
Rollmodl
Responsify is also asking for a download key
The Plyr plugin is causing an issue with the Responsify Full Width Display option. Disabling Ply should fix this issue.
Use your JCE Pro Subscription Key.
Rollmodl
That worked, Thanks.
