#117343 compabtibily between JCE pro and phoca galery extension
Latest post by ppm58 on Wednesday, 24 September 2025 18:17 BST
ppm58
I am having a compatibility issue between JCE Pro and the Phoca Gallery extension. Apparently, JCE Pro does not recognize the Phoca Gallery codes used to display images. Do you have a solution? Thank you for your help. Best regards, Pascal
Are the codes being removed? What is happening to them?
ppm58
I have provided an example. In the article, you have the edit mode where the Phoca Gallery code appears. In preview mode, only the photo titles appear (the photos are reduced to tiny empty squares). In code mode
The photos are clearly visible in the frontend.
Are you referring to the Preview tab in the editor?
Phoca Gallery processes its codes in the front-end to display the galleries or images. The JCE Preveiw tab provides a simple preview of the editor content, not the final output of what will be rendered in the front-end.
ppm58
OK, so there's nothing wrong. Thank you very much for your help.
