#117387 JCE Pro 2.9.94 error white file system
Latest post by Ryan on Thursday, 09 October 2025 19:43 BST
roland_d_alsace
Hi.
With JCE PRo 2.9.94 i have an error when i want to uplod file or picture
A simple popup with "error" an a cannot upload file from pc to server.
The updload directory is blank (the direcoty in the profils is "documents/2026/$username" and the folder is well created by JCE)
 A need to downgrade to 2.9.93 for soluce the problèm.
Regards
Where are you uploading the file? Is this in a media field, or using the Image Manager etc. in the editor?
roland_d_alsace
Hi Ryan.
In the editor, via JCE plugins.
But i must look, i have a return for a specific plugin (not a jce plugin) wich said :
Call to undefined method WFJoomlaFileSystem::processPath()
The problem is perhaps here.
Have you change something in your framework ?
Yes, a lot has changed.
What plugin is this?
