#117396 problem with popup
Latest post by Ryan on Friday, 17 October 2025 09:44 BST
[email protected]
Hello Ryan,
On this page of a site : https://www.roquebrun.fr/?view=article&id=2108:mportant-secheresse-diffusion-de-larrete-de-restriction-des-usages-de-leau-du-14-octobre-2025&catid=13
I have a problem with a pdf that does not pop up as it usually does. The pdf icon is showing in the article, and alsoworks, but the text that normally shows a the basis for the link does NOT, whatever i choose : replace text or not. Version JCE = 2.9.95. I've used the pop-up option multiple times, but I don't get it now. Could you take a look, please?
Thanks in advance, Jan
When creating the link, set the Popup Icon option in the Popups tab to No.
[email protected]
Sorry Ryan, your suggestion did not work. But it is getting worse, although JCE might not be at fault. I upgraded multiple "sound" sites to 5.4  yesterday and have different problems which each of them. Tried to roll back one site to 5.3.4 with Akeeba Pro but ended up with a total mess so I left the others in their crippled state… Nicolas from Akeeba hasn't even answered. This might be the end of my joomla era.On that site the front category blog does not even accept new articles, go figure. What a flop this time…
Jan
You would need to update the existing popup link. This removes the popup icon on the link, which is what was hidding the link text, nothing more than that.
Please send me a login so I can troubleshoot this issue - https://www.joomlacontenteditor.net/contact/site-login
