09:00 - 17:00 UTC (BST)
#99264 JCE pro 2.7.7 not working
Latest post by nhtim on Friday, 12 April 2019 09:08 BST
marcske456
Hi There, I have been using jce for more than a year now. Since a week or 2 I can no longer use JCE. When I start an article, JCE just doesn't appear anymore. I already upgraded to JCE 2.7.7 pro and 2.7.8 pro without result. JCE is certainly active and in the Joomla settings JCE is the basic editor. At the user part he is set correctly per user. I use Joomla 3.9.5 Can anyone help please
This appears to be a conflict with the version of SP Page Builder you are using. Please update SP Page Builder, or disable the Joomla Article integration in SP Page Builder -> Integrations.
nhtim
Ryan, I have also noticed a problem with JCE. I only get a blank white page when I try to go to the JCE editor Pro component Control Panel. I tried reinstalling 2.7.8 from scratch, but got an error message after uploading and installing. The editor tools are there when you edit an article. I am running Joomla 3.9.5 w/ PHP 7.2.17 & SQL 5.6.41-84.1 and all extensions are up to date and working correctly. The only extension that is affected seems to be JCE. Can you help? Thanks, Tim
@nhtim - Please send me a login - https://www.joomlacontenteditor.net/contact/site-login
nhtim
Ryan, Info sent Thanks, Tim
@nhtim - I have fixed this on your site with an install of JCE Pro 2.7.8
nhtim
Thank you, is there a reason I got an error message when I tried the upload and install of 2.7.8 myself?
That depends on the error message. Can you recall what it was?
nhtim
The message only said "error" in the pink box after upload and install attempt. UPDATE! I think I had a browser cache issue. I had it happen with another app and clearing cache solved it! Thanks, Tim
