- help me enable thumbnails and popups for image and media
Do you have the Image Manager Extended installed?
https://www.joomlacontenteditor.net/component/zoo/item/image-manager-extended-4
Follow these steps:
1. Open the Image Manager Extended.
2. Select an image. This will be the thumbnail image that the visitor clicks on. You might want to change the width and height, eg: change the width value to 200 (the height value will change automatically)
3. Click the Popups tab.
4. Select JCE MediaBox from the the Popup Type list.
5. The image above will already be in the URL field, but you can select another image if you like.
6. Click Insert.
OR
If you created a thumbnail for the image when you uploaded it, skip step 2, and just select the image when you are in the Popups tab, then click Yes to the "Use associated thumbnail for popup link?" message that appears.
6. Click Insert.
OR
