- How to showtime-related changing images in an article?
make a series of images which simply change on a 24 hour basis within an article? Does one of your additions/extensions do this?
No.
Or how else can it be done? (Widgetit doesn't do it.)
I don't know of any extension that does this. There may be some gallery extension on the JED - http://extensions.joomla.org/ - but you'd have to search for it (if it exists).
#83086
I'll take a look, thanks Ryan.
In the meantime I'm trying Random Image module, placed into the Article with Modules Anywhere (I couldn't get LoadModule to work.)
Cheers, Robin
Cheers, Robin
