- JCE Plugins / Addons
- image upload problem
You did not have JCE Pro installed on the site.
I have installed JCE Pro 2.6.1 and uploads are working as expected.
Please make sure you clear your browser cache before using the editor.
Please install JCE Pro 2.6.1 - https://www.joomlacontenteditor.net/downloads/editor/pro/item/jce-pro-261-2
Clear your browser cache.
#88082
I am seeing the same issue. It's not the upload of the file that is the problem. When you select the file (image) you're interested in, the plugin used to put the full path name to the file in the URL field and then when you pressed Insert to pull the image in to your document it would work. The plugin is no longer filling in the URL field, so the insert fails.
I hope that helps.
Cheers, Mark
I hope that helps.
Cheers, Mark
You don't have JCE Pro installed. Please download and install JCE Pro 2.6.1 - https://www.joomlacontenteditor.net/downloads/editor/pro/item/jce-pro-261-2
