Mediabox code
We have found that when we anable mediabox plug it its generate a extrange code in all site pages:
I have JCE installed un other Joomla sites and this code not appear.
Could you tell me if this code in all site pages is correct behavior?
PS. Pop Up works fine is just that we have checking the pages code and found this.
Thanks in advance.
<script type="text/javascript">
JCEMediaBox.init({popup:{width:"",height:"",legacy:0,lightbox:0,shadowbox:0,resize:1,icons:1,overlay:1,overlayopacity:0.8,overlaycolor:"#000000",fadespeed:500,scalespeed:500,hideobjects:0,scrolling:"fixed",close:2,labels:{'close':'Cerrar','next':'Siguiente','previous':'Anterior','cancel':'Cancelar','numbers':'{$current} de {$total}'},cookie_expiry:"",google_viewer:0,pdfjs:0},tooltip:{className:"tooltip",opacity:0.8,speed:150,position:"br",offsets:{x: 16, y: 16}},base:"/",imgpath:"plugins/system/jcemediabox/img",theme:"standard",themecustom:"",themepath:"plugins/system/jcemediabox/themes"});
jQuery(window).load(function() { var $ = window.jQueryNivoSlider || jQuery; var opts = {"animSpeed":1500,"pauseTime":1500,"controlNav":false,"randomStart":true,"responsive":true}; $("#ais_132").nivoSlider(opts); });
window.setInterval(function(){var r;try{r=window.XMLHttpRequest?new XMLHttpRequest():new ActiveXObject("Microsoft.XMLHTTP")}catch(e){}if(r){r.open("GET","/index.php?option=com_ajax&format=json",true);r.send(null)}},840000);
</script>
Thanks in advance.
So, this both (mediabox and slider) code is correct to show in the page code or there are any issue with loading js or anything else?
The MediaBox code is correct.
It is common practice to load some javascript in the document head in this way.
This is the MediaBox initialisation code.
This is not Mediabox code, it appears to be related to jQueryNivoSlider.
This is Joomla code.
#83477
Ok.
So, this both (mediabox and slider) code is correct to show in the page code or there are any issue with loading js or anything else? (Im not a programmer so that code seems little little weird compared with othe and becouse it is near to the head code)
For example, I have other like you can see at the attached image.
Not shows all code, just loaded.
But media box shows all code.
Is it correct?
Thanks in advance!
Is it correct?
Thanks in advance!
