I was contacted by a client that the popups changed. I solved some of this like showing the magnifying glass, that's a setting.
But now the transition is not like the images slide, but disappear and than come back. The client think that's to restless. But I see no option to change that. Is it possible the old way. You can see how it is now here: https://bluetrout.nl/work/128-shimmer and click on one of the small images.
Also if I change the background I can't change the color of the text. Do I have to do that in my stylesheet? Would be nice if that was just a setting.
I use JCE pro and mediabox on J3 in this case. The only settings I have are (see image):
