#111569 Icône Tooltips CG is not visible in JCE Pro (but ok in Tiny)
Latest post by Yvjo on Monday, 01 August 2022 17:15 BST
Yvjo
Hello
I use tooltips from regular lab in my Joomla 3 site https://www.marketingformation.ch . I need to upgrade to Joomla 4 and there is no compatible version at Regular lab.
I bought Tooltip CG from JoomlaCK.
I can't find the button that should be added to JCE Pro (last beta version).
In Tiny MCE it works.
Do you have any editor-xtd buttons displayed at the bottom of the editor?
Yvjo
No !
It works wirh Joomla 4 but not in jommla 3.10
Have you added the Joomla button (the one with the Joomla logo) to the editor toolbar?
When this button is added the toolbar, the editor-xtd buttons usually displayed below the editor are added to a menu accessed from this button.
Yvjo
Yes the Joomla button is added and now if I click on this button I see more buttons, but not below
Thank you
Yes, the is the expected behaviour. With this button in place, the buttons below the editor are not shown.
Yvjo
and how to remove the Joomla button so that they are at the bottom?
[quotePost id="111587"]and how to remove the Joomla button so that they are at the bottom?[/quotePost]
The same way you added it, in Editor Profiles -> Features & Layout. Drag the button out of the Current Editor L ayout back into the Available Buttons & Toolbars.
Yvjo
Thank you
