Here is my problem, I use the mediabox popups, the display of photos on the iphone in vertical position is perfect, however in horizontal position, the photo is displayed full screen for a fraction of a second and it becomes very small .
In a previous message, addressed to the forum I thought it came from the numbers corresponding to several photos of the same group, Ryan had given me the solution to remove the numbers, thank you again the solution works perfectly, unfortunately even without the number image is not full screen in horizontal position, on the other hand as can be seen on the attached images, the figures, the title or the legend are positioned vertically in horizontal position.
Is there a solution, maybe I didn't make a necessary setting. I tried to enter different height and width values in the mediabox settings but no change, I downloaded version 2.1.3 RC3, no better!
If you have a solution...
