- Using ChatGPT
Using ChatGPT
We have just seen a plug-in for Joomla 4 called ChatGPT - you can find it here - https://github.com/R2H-BV/chatgpt
Is it possible to have this included as part of the JCE Editor as per this video - https://www.youtube.com/watch?v=dUa9JhV1TU4
If I swap back to the TinyMCE editor it does show up under the CMS content dropdown
Rich
Rich
#113975
No worries we can wait till you have had time to check it out
The screenshot you sent - were is that available?
We have the JCE editor but cannot see any reference to ChatGPT
Cheers
Rich
Cheers
Rich
It's a JCE plugin I'm working on, and I'll release a beta next week. Similar to the ChatGPT plugin you linked to above, but accessed from the JCE Editor toolbar.
FYI - This plugin is working fine in my tests with JCE.
