#116294 DL, DT and DD
Latest post by hing on Friday, 01 March 2024 14:36 GMT
hing
I have still troubles to use DD and DT in a handy way. It defines always DT when I select DD.
See the screencast here: https://1drv.ms/v/s!As0XWvf-DK0DhFjwEAjwsUOAQ-1e?e=ozj6OI
Is it necessary to define the entire range as DL in a first step and then to apply DT and DD?
Thanks and regards
Peter
Please try JCE Pro 2.9.63 Beta - https://www.joomlacontenteditor.net/downloads/editor/pro/development
You can now make a selection of paragraphs and select either DT or DD from the Format list to create the Definition List. The first paragraph will be set as a DT and the others as DD. You can then convert DT to DD and back as required using the Format list, eg:
https://cdn.joomlacontenteditor.net/tmp/116294-dl-dt-and-dd.gif
hing
Thanks, works as shown above
