#117247 Popup not working as they should
Latest post by ltempest on Tuesday, 17 June 2025 13:41 BST
ltempest
Hello, On my clients site:
https://www.flashlube.com/products/catch-can-pro
If you scroll down to the table towards the bottom of the page in the right hand column is an icon for a camera. When clicked this should link to a popup of the image. However clicking does nothing. You need to right click on the icon and open in new tab.
Can you please advise on how I can correct the page so the popup image appears when the icon is clicked.
Whatever you are using to compress or cache the HTML, scripts etc. on your site may be causing the issue.
System Task
system
The ticket information has been edited by Lee Tempest (ltempest).
ltempest
Odd, I have turned off JSpeed plugin and flushed the cache numerous times, but still get nothing :-(
Could it be because this table is in a module loaded on the page and not part of the article? I did check the prepare content option as a check as well.
Can I send you login details to take a look?
The template's CSS Compression / Optimize tool seems to be causing an issue with the MediaBox css.
ltempest
Ryan,
Genius! thanks so much that worked :-)
