info
MediaBox
Monday, June 06 2011, 10:20 PM
mbrown0036
mbrown0036
Offline
I installed the MediaBox, and it appears in the editor, however the popup window is basically frozen, minus the close button. No files appear and when I enter a relative path to a file, the insert button does not work. Any ideas?
Responses (3)
  • Accepted Answer
    Admin
    Offline
    Monday, May 13 2013, 09:11 AM - #permalink
    You could try something like this :
    1. Select all the images to be included in the popup
    2. Click the Popups tab and select WidgetKit from the Popup Type list.
    3. Click the Insert Multiple Images button
    4. Set your WidgetKit popup options
    5. Set a Group name for the popups.
    6. Click the Advanced tab and in the Style field add : display:none;
    7. Click Insert
    8. click the Source Code Editor button.
    9. Find the first link with the data-lightbox attribute and remove the style="display:none;" from its child img element.
    The reply is currently minimized Show
  • Accepted Answer
    macman
    macman
    Offline
    Sunday, May 12 2013, 05:52 PM - #permalink
    Hello from Greece,
    is there a link with the instructions on how to use the Yootheme widgetkit plugin with a single thumbnail image gallery?
    Thank you in advance
  • Accepted Answer
    Admin
    Offline
    Tuesday, June 07 2011, 12:18 PM - #permalink
    What JCE version are you using? MediaBox does not provide a dialog for the editor, are you referring to the Media Manager?
